I made the .d2v file needed, I converted it into an .avi with TMPGEnc. I then took the .ac3 file, and converted it to MP3. I then used NanDub to join the audio and video. The first screen that comes up is the "This DVD has been formatted to fit your screen" and the audio begins to play at this screen, so its out of sync from the start. How would I go about setting an audio delay so the audio will come in at the appropriate time? Would I have to add a few seconds of silence to the movies audio or what? Any recommendations on tools to use and methods of doing this would be appreciated.
You should have got A/V delay info when you ripped DVD. Use this info in audio interleaving dialogue and you should be OK.
You really should rip in IFO mode. If not, synch problem might happen.
If all these fail, nothing can help you but your eyes, ears, and a stopwatch. You have to estimate A/V delay by yourself and adjust it by trial and error......
Having sync issues with DVD Flick?
By bahjan in forum Video ConversionReplies: 3Last Post: 31st Jul 2011, 14:50 -
sync issues with DVD to DivX conversion
By snafubaby in forum DVD RippingReplies: 12Last Post: 24th Dec 2008, 02:10 -
Divx sound sync issues
By hotsalt in forum Video ConversionReplies: 1Last Post: 11th Apr 2008, 14:18 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
MKV to DVD Sync Issues
By snadge in forum Newbie / General discussionsReplies: 0Last Post: 13th Jan 2008, 08:12
