I am having a problem encoding with TMPGenc. I have ripped a movie with smart ripper and DVD2AVi which has been fine.
Now when I try to load the file in TMPGenc the settings are greyed out and I cannot alter the bitrate setting or change the file size.
I have tried unlocking it but nothing changes.
Can anyone tell me what to do please
are you trying to make a vcd or svcd...if you are trying to make a vcd compliant video, it will block out all the boxes except motion precision. You would have to tell it to make a non compliant vcd to get to the 'greyed out' boxes.
Select Load go into the Extars folder and select the unlock template. Now try to adjust your settings.
Hello. -
Originally Posted by Tommyknocker"Art is making something out of nothing and selling it." - Frank Zappa
Thanks, Zippy.P. The drugs have not kicked in yet.
Hello.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 15:07 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
