  1. Hi all,
    small question, just to be sure everything is normal.
    I'm doing VCD with ffmpegX since a long time. Now I switched to 008b (I guess c has the same features for VCD.
    I installed the new binaries as well, as mpeg2enc was changed.
    Now doing as usual, with the VCD PAL preset, enabling the terminal, to check what's going on : same messages as usual, but my m1v file is not growing, it's 152 ko since 15 minutes...
    Something wrong ?
    Terminal output :
    Encoding started on Tue Sep 16 21:13:58 CEST 2003
    ## Component Manager: attempting to find symbols in a component alias of type (imco/SVQ3/SMI )
    ## Component Manager: attempting to find symbols in a component alias of type (regR/carP/x!bt)
    a52dec-0.7.4 - by Michel Lespinasse <walken@zoy.org> and Aaron Holtzman
    No accelerated IMDCT transform found
    a52dec seems a new step there : before I only had the first output lines.
    I am on 10.2.6 with a G3 400DV, latest binaries, all normal I think.
    Did anyone experience the same ? Will the encoding start later ? (like it's now working on a temp file I don't see ?) Thanks for any hint. Otherwise I'll have to go back to 007 and old binaries
    iMac 400 DV (So what!) - 512 Mo RAM - HD 50 Go - Panther
  2. Sorry I disturbed !
    My vob has a problem, it works with other vobs !
    I'll learn to post more slowly next time
  3. Guest
    Hi again,
    however, the "non working" vob is accepted if I use the older versions and ffmpegX and binaries.
    Does anyone know what are the requirements of ffmpegX/mpeg2enc to see the vob as "valid" ?
    I know it's a difficult question, but maybe there's an obvious trick I can't see.
    Thanks for any hint
