The last few VCDs I've created, when played, look great, sound great, except.... there is a squeak-chirp-pop. I don't know how to explain the sound that you hear every once in a while when viewing. Does anyone have a clue? These are files I converted from AVI to mpeg. I tried extracting the audio and not extracting the audio. I tried noise reduction. I have no idea what to do.![]()
I am not sure what the problem is, but does the sound occur in the avi and mpeg files on your computer, or is it just on the VCD?
Not sure if this will help you, but I once had a problem with clicking sounds on a audio CD. It turned out to be the drive that I was extracting the audio from. By using a different drive, the clicks went away. Are you ripping the video from something?"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
Well,I once faced the same problem .The pops and clicks are in the original source, but they are very soft.You pay attention ,you can hear them. Somehow when the conversion took placed, they gets amplified in the final sound!!!I tried using Goldwave to correct, unfortunately with limited success. Are you getting the same fault with all your avi? Try to do a clean avi conversion.
I had this problem when making a Photo VCD and inserted background music from MP3 files. When I changed my audio codec the problem disappeared.
I have had this problem many times expecialy from copied copied copied copiedVCD's. I suggest demux the file and re mux them back together..workes everytime. Use Tmpenc tool simple demux .then remux...read the guide to repairing a broken mpg file over there in the guides section on the left
Better yet
https://www.videohelp.com/forum/userguides/126673.phpHow long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
If you like Tekno download one of my tracks
www.users.bigpond.net.au/thefox149
What is this pop up on Vhelp ?
By Noahtuck in forum FeedbackReplies: 3Last Post: 18th Aug 2010, 15:08 -
Pop up doesn't go away
By jyeh74 in forum ComputerReplies: 20Last Post: 22nd Sep 2008, 04:54 -
Pop-up video
By uniks in forum Newbie / General discussionsReplies: 19Last Post: 29th Aug 2008, 21:44 -
Metallic "chirp" when appending flv segments with flvbind
By brassplyer in forum Video ConversionReplies: 4Last Post: 6th May 2008, 18:14 -
A pop up
By imkool in forum Software PlayingReplies: 1Last Post: 19th Feb 2008, 12:11
