I am trying to back-up Final Destination 2 using DVD Shrink 3 Beta, I have first used DVD Decrypter.
I cannot get DVD Shrink to compress this movie enough to fit onto a DVD-R, I am wanting to keep all the language and extras.
Can I force DVD Shrink to compress even more?
Automatic compresion gets the movie down to 4,648 MB
Ratio will only allow me to go as low as 54%
Thanks in advance.
Kernal
Hey I did shrink Final Destination 2 it was hard to figure out but finally did it with dvd shrink 2.3 in order to controll compression a little more but dvd shrink is all that I use now.
I've had this problem with DVD Shrink 3.0 beta 5 too (not sure about 2.3). Where I can not lower the percent shrink bar below a certain minimum (normally the automatic value) and as a result I still can't compress my DVD9 to fit on a single DVDR.
I think/hope it's a bug in the program (still beta). For 2.3 you can always drop the levels. -
Always use DVD Shrink v. 2.3 as DVD Shrink 3.0 beta 5 is useless?
I compressed Lord of the Rings 2 onto 1 dvd-r. If I can compress that size movie, then you can compress that smaller movie you have -
DVD Shrink 3 beta5 had NO problem doing Fellowship of the ring and Two Towers for me. Both are 3hr movies!
It is NOT useless! I also have 2.3, but have only ever used it once or twice, then I was told about beta 5 and used it for all the rest. Both are great!
I have done several other movies with it also, none have had any problems not working, or any quality problems.
Exactly my thoughts also for beta5I compressed Lord of the Rings 2 onto 1 dvd-r. If I can compress that size movie, then you can compress that smaller movie you have
I even did one DVD9 I that had over 8gigs for sure, it had both widescreen and full screen versions on the same disk. Beta 5 had no problems with that one either.
The only thing I normally change is that I will remove extra langauges I have no use for, like french or spanish. I don't speak them or understand them, so why take up space with them? I often remove them, but not always.
Authoring oversized DVD, then shrink to fit on a disc?
By adamberkey in forum Authoring (DVD)Replies: 1Last Post: 28th Apr 2012, 00:39 -
Shrink Xvids to fit episodes on DVD
By Wolfbrain in forum Video ConversionReplies: 5Last Post: 20th Apr 2009, 12:40 -
how to shrink a movie to fit a dvd 5?
By just in forum Newbie / General discussionsReplies: 2Last Post: 30th Oct 2008, 00:58 -
GUI for DVDauthor - Fit/shrink output to 4.7G DVD
By pannayar in forum Authoring (DVD)Replies: 5Last Post: 14th Aug 2008, 23:49 -
Q: Adaptec AVC-2310 MPG2 Capture - Need: Shrink/Fit to DVD, Redo Audio
By jpneok in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jun 2007, 20:06
