When I convert 23.976fps AVI file to NTSC DVD the time of the movie is diferent from the original (about 5-8sec. less). With PAL DVDs everything is OK. Any suggestions?
You mean
23.976 AVI -> 23.976 MPEG2 is different
25 AVI -> 25 MPEG2 is the same ?
Check the 23.976 frame rate with Vdub
and also see if there are bad frames -
I mean when I load 23.976 AVI file in TMPGenc DVD NTSC Project the resulting M2V file is "time" shorter that the original AVI file (about 5-8sec.)
Example - AVI file - time 1:30:29:500, M2V file - time 1:30:24:280.
It is not a big problem but if I deside to insert subtitles, these 5-8sec. are big problem
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 14:38 -
Problem with TMPGEnc
By The Monkees in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 15:58 -
TMPGEnc Problem
By djkevyb in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 15:46 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 17:56
