Keep an eye on mpgtx - last time I looked, it still had muxing on the TODO list, but who knows?!?
/Mats -
various locations. Here's one http://themurrays.homeip.net/downloads/tivo/for_windows/mplex1_6_0.zip
you need to have the cygwin1.dll in the same folder as mplex.exe - thats all
Here's the usage.....
the way i use it is:Code:mjpegtools mplex-2 version 1.7.0 Usage: mplex [params] -o <output filename pattern> <input file>... %d in the output file name is by segment count where possible params are: --verbose|-v num Level of verbosity. 0 = quiet, 1 = normal 2 = verbose/debug --format|-f fmt Set defaults for particular MPEG profiles [0 = Generic MPEG1, 1 = VCD, 2 = user-rate VCD, 3 = Generic MPEG2, 4 = SVCD, 5 = user-rate SVCD 6 = VCD Stills, 7 = SVCD Stills, 8 = DVD with NAV sectors, 9 = DVD] --mux-bitrate|-r num Specify data rate of output stream in kbit/sec (default 0=Compute from source streams) --video-buffer|-b num [, num...] Specifies decoder buffers size in kB. [ 20...2000] --lpcm-params | -L samppersec:chan:bits [, samppersec:chan:bits] --mux-limit|-l num Multiplex only num seconds of material (default 0=multiplex all) --sync-offset|-O num Specify offset of timestamps (video-audio) in mSec --sector-size|-s num Specify sector size in bytes for generic formats [256..16384] --vbr|-V Multiplex variable bit-rate video --packets-per-pack|-p num Number of packets per pack generic formats [1..100] --system-headers|-h Create System header in every pack in generic formats --max-segment-size|-S size Maximum size of output file(s) in Mbyte (default: 2000) (0 = no limit) --split-segment|-M Simply split a sequence across files rather than building run-out/run-in --help|-? Print this lot out!
mplex -f x -o output.mpg video.mpv audio.mpa
where x depends on what your doingSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Script to mass convert VOB's to MPG's from the command line
By casperinmd in forum SVCD2DVD & VOB2MPGReplies: 13Last Post: 3rd Jan 2013, 16:08 -
CrossPlatform command line tool to multiplex avi files?
By Selur in forum Newbie / General discussionsReplies: 0Last Post: 23rd Mar 2012, 15:29 -
Command line convert mpg to mp4
By csc12345678 in forum Video ConversionReplies: 1Last Post: 30th Dec 2010, 09:11 -
Command-line command for fixing AVI?
By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 02:23 -
command line
By exekutive in forum ffmpegX general discussionReplies: 22Last Post: 1st Jun 2008, 23:44
