  1. i cant find it!!! i wanted to remove the warning at the beginning by following the guide, and i wanted to copy the entire disc. so i clicked "entire disc" and "start". it didnt let me choose the path. once it told me to insert blank disc, i DIDNT, and tried to find the saved files. but i cant find them....i tried searching for "video_ts" and no luck. i went into the c:\windows\temp folder. found nothing, and it was around 30MB big so couldnt have a movie (attack of the clones). i did the same with c:\documents and settings\my username\local settings\temp and same thing. couldnt find it, the folder was only 80MB big so i figured impossible. does anybody know where they're stored? im using windows xp pro by the way...
    thanks
    brian
    Apr 2003
    Largo, FL
    Before you click "start", click "Options"- then you can choose the path for the temporary files.
  3. did you close the program? if you did, then dvdcopy xpress deletes the temp folder. I think there is a way to change directories because I have mine set to the desktop. If you want to take out the warning screen, you have to leave dvd xpress open when it gets to step 2. or when it gets done and asks you for a blank disc, do CTRL, ALT, DELETE and go to your started task and end the process for XPRESS.EXE. that will close dvd xpress and let you keep the temp folder labeled DVDXPRESS.
