Hello, Nero Vision Express 2 - Burning from avi -> dvd causese the audio to be waaay out of sync (audio slightly faster than video) how can i fix this?
You could try convert the audio to wav. Use for example virtualdub, open the avi, select under video->directstream copy and under audio->full processing, select file->save avi and you will get a new avi with wav audio(the video will NOT be reconverted). Open the avi in nero vision express and convert to dvd.
Or convert the avi to dvd mpeg with tmpgenc, cinemacraft encoder basic or mainconcept mpeg encoder instead, and only author and burn with nero vision express (it should not then convert it again, only burn it).
Troubles burning avi to a dvd with nero vision
By falcon1 in forum Authoring (DVD)Replies: 3Last Post: 13th Oct 2008, 12:36 -
Nero Vision Express 2- DVD-video/merge titles causes stuttering
By mookster in forum Authoring (DVD)Replies: 0Last Post: 18th Jun 2008, 11:44 -
Encode mpeg-1 layer 3 in AVI to AC3 surround in Nero Vision Express 3
By jimbojr in forum AudioReplies: 0Last Post: 18th Feb 2008, 20:51 -
Recording audio with Nero Vision 4 Express
By SEE_Studios in forum AudioReplies: 3Last Post: 21st Jan 2008, 16:28 -
AVI won't run in Nero Vision Express 3
By loninappleton in forum Video ConversionReplies: 3Last Post: 9th Oct 2007, 14:33
