  1. Hi,
    I tried to copie LotR2 with DVD-Shrink (Vers. 2.3 and 3.0) but it has a copy protection.
    Then I tried DVD-Decrypter on it - no chance.
    I someon out there who can help me? Give me the name of a good progr.
    thx to all out there!!!!
    Apr 2002
    The State of Frustration
    You have two of them. Just play the disk in your computer for a minute and then try either one.
    Hello.
  3. You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
  4. I used dvd decrypter, then used dvd shrink 2.3. I compressed the extras and menu to still pictures and compressed the main movie to Level 9.
    It came out perfectly for me. I dont know what you did wrong.
  5. I just used AnyDVD and DVD Shrink 3 Beta5 and everything works great and did a deep scan and I can't tell which is the orginal one. You can't go wrong with AnyDVD works like a charm.
  6. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    DVD Decrypter works perfectly fine. make sure you have the latest version, i had an older version and it kept failing. so i installed the latest version, no problem from there onwards.
