Hey I have treid to make few dvd;s with workshop and evethying is fine excpet when i wathc it the audio is way off from the video. Any hints on correcting this or could i save it to directory and burn usign another program, only question on this woudl be do my menus created with workshop get burned on there as well or will it jsut be the movie, thanks guys
If your having audio sync problems, I'd write the DVD to your hard drive first as _TS folders and then play with computer DVD player software. If it's in sync then burn the folders to a DVD_R or +R.
If you are having sync problems on the computer you need to go through the process of how you are creating your MPeg2 files to find the answer.
If you are using DVDWS for capture to burn then you may need to try using another program for creating your MPeg2 video files.
Question about Subtitle Workshop
By tcory in forum SubtitleReplies: 1Last Post: 15th Jul 2011, 23:10 -
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 02:04 -
Subtitle Workshop 2.51 question CLI vs Gui.
By Maikeru-sama in forum SubtitleReplies: 0Last Post: 4th Jul 2008, 21:27 -
Video is upside down in DVD Workshop 2
By darkcyber in forum Authoring (DVD)Replies: 12Last Post: 7th Oct 2007, 21:22 -
DVD Workshop 2 on Vista
By jaffacaique in forum Authoring (DVD)Replies: 6Last Post: 22nd Aug 2007, 09:16
