Just in case you need to know: System NTSC.
Which one, Huffyuv or DVSoft (basically regular DV compression but you are allowed to change the default 29.97fps to whatever you want) creates a lower data rate? I am tempted to use Huffyuv because of it's lossless compression but I don't know if the data rate is too high (resulting in a file too large for my HD)? DV compression/DVSoft runs at ~3.16Mbyte/sec (with small compression artifacts). Can anyone tell me what data rate Huffyuv runs at?
And can TMPGEnc open AVI's compressed with the Huffyuv codec?
Thanks for your time...
AP Enterprises Ltd. -
i capture with huffyuv. i don't know the data rate of it but i can tell you that 4 gigs is 15 minutes worth of capture. at least for me it is. i've tested many others but the quality has been the best for me. i have a 40 gig drive and i only use about 9 gigs so i have plenty of space for capture and conversion.
I regularly encode @ 480x480 w/the Huffyuv codec with a compression ratio of 2.5-2.7:1 and get a bitrate of 1536kbps give or take a few. I get approx. 1hr on 20gig of hard drive space w/the audio added in. TMPGEnc has no trouble wtih this.
Frameserve if you have to, but useing a lossless codec before you encode w/a lossey one is better -
dbman, this is odd, I heard that 1 hour of DVSoft is equivalent to 20Gb but you said that 1 hour huffyuv is also equivalent to 20Gb? How can this be??!! DVSoft is ~3.16Mbyte/sec at 704x480! And you said that huffyuv is ~1.6Mbyte/sec at 480x480! This makes no sense!! Either DVSoft should be twice of 20Gb, or huffyuv should be half of 20Gb. Odd... Odd...
AP Enterprises Ltd.
huffyuv help
By liquidr0x in forum Video ConversionReplies: 31Last Post: 18th Feb 2015, 06:31 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 14:29 -
Please explain codecs to me: codecs within codecs?
By idsane in forum AudioReplies: 5Last Post: 2nd Sep 2008, 14:39 -
Vista Codecs - New PC Requirements - Are Codecs Needed
By doggyofone in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 19:52 -
How can I uninstall Huffyuv?
By Xoanon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 15th Jun 2007, 09:55
