I'm new to dvd burning. I just got my dvd burner and need some help. I downloaded dvdshrink and loaded a dvd into my burner. DVD encountered a error saying the disk is copy protectedand it was encrypted. How do I get around this? What programs should I use? After using it what do I do next?
Thanks giro
You could do 2 things. One first try playing the movie in PowerDVD or WinDvd and then run dvdshrink and see if that works. If not then get dvddecryptor or smartripper and then rip the whole thing to the hard drive then point dvdshrink to it and hopefully it will work for you. Be advised you will need a good deal of space somewhere around 10gb to rip a full dvd.
sparker366a@gmail.com
The net is a wonderful place to waste time. You can wade through great information and garbage. But then we are only Human -
There are loads of guides on the left, also have a look at places like doom9.org. If you're going to use DVD Shrink then a lot of those guides will be over your head, but if you've only just found out DVD's are encrypted, then you might like to do a little homework. It's not as easy as backing up CD's, I'm afraid.
Good luck !
BlueRay burning software and other questions
By garyknowz in forum Blu-ray RippingReplies: 3Last Post: 22nd Jan 2009, 22:10 -
I'm New to Burning DVDs: I have quite a few questions
By emoney3265 in forum Authoring (DVD)Replies: 15Last Post: 13th Aug 2008, 17:00 -
Burning HD to normal DVD + other questions
By Gaelstrom in forum Authoring (DVD)Replies: 4Last Post: 30th Oct 2007, 18:02 -
new to dvd burning - questions!
By tiredbunny in forum Newbie / General discussionsReplies: 3Last Post: 8th Sep 2007, 12:00 -
This Newbie has a whole lotta questions about DVD burning
By HartsVideo in forum Newbie / General discussionsReplies: 49Last Post: 14th Jul 2007, 01:04
