I have multiple files in mpeg & AVI format they ewqaul just about 3.75 gb...How can I burn these to one dvd with menu
Any help would be appreciated
razz
Results 1 to 19 of 19
Well, Ok first, You can only burn both the mpeg and AVI to a dvd if you only plan to view it with your computer, if you want to view with a dvd player then the AVI must be converted to vcd or svcd, I SUGGEST VCD because goin to SVCD will look realy bad quality wise. how compressed is the AVI? The mpeg you can just keep as is just make sure it meets all criteria for burning in the program you are using, I use tmpeg DVDenc and tmpeg dvd author. As long as the mpeg is the rite frame rate,bit rate, and screen size your good to go. screen size is 720x480 for dvd and vcd is 352x240 and svcd is 480x420.
As SHADY as you wanna be! -
SVCD is much better quality than VCD! And you can have a DVD compliant file with resolutions other than 720x480.Originally Posted by Shadyripper
Yes SVCD is a much better quality than VCD however when converting an AVI it will look better if you convert to VCD rather than to SCVD depending on how compressed the avi is if your using an AVI that is very compressed then I would convert to VCD if the AVI is not compressed much then SVCD will look ok. and I was only giving good screen size not saying this is the only size.
Before giving such advice, you really should know what codec is used in the AVI. A DV format would die at VCD by your logic.
This being said, what kind of "AVI" is this ?Want my help? Ask here! (not via PM!)
Mmmm REALLY ? what standard is that then?and svcd is 480x420
I think everyone is complicating the issue. Take your avi's into tmpgenc and convert them to either svcd or vcd (svcd is better quality but will take up more space). However remember when you convert your avis the file sizes will get larger, also you will need to pay attention to different frame rates.
Once all of your files are in mpeg format take them through to tmpgenc dvd author. Load them in and click create. When this has finished you will have a video_ts folder that you can burn with your favourite program (I use nero). I have not gone into any details as guides for all of these processes can be found on the left hand bar.
However if you get stuck feel free to pm me.
Russ -
I Guess we are hardcorerus.
*Roderz* Woops 480x480 my mistake.
*Lordsmurf* I was asuming he can play the AVI on his comp already which has the codec. what type of AVI is it thoughAs SHADY as you wanna be! -
480 x 576 for PAL, 480 x 480 for NTSC.Originally Posted by dogbolt
And why is everyone talking VCD and SVCD anyway when he says he wants to burn to DVD. -
Just beat me to it FOO
I was wondering what all this vcd and svcd talk was about. LOL. Poor guy asked about a dvd. One thing for sure that somebody mentioned was that the avi will get bigger after it is converted to mpeg and the total size may or may not fit on one dvd. My suggestion is to encode the avi to mpeg2-dvd and then use dvd author to combine all the dvd mpegs. If the resulting size is too big, then just reduce it with dvd shrink.
Craig
Brilliant minds think alike, even when some of them
are in the colonies. -
Ok I tried to convert the avi's to mpeg2 in tmpgenc plus...but all I get is the video no audio......any other suggestions..
Razz -
Find out what kind of audio it is and if necessary separate it
and change it to something more appropriate -
Foo, How do I find out what the audio is ....I have virtual dub and tried to use that but I havent a clue
Your problem is non-trivial because you said you have multiple files in
multiple formats.
MPEG and AVI tend to be in different classes They need to be treated sepatately.
There are lots of programs that will give a clue, but only if you pretty
much know what they are already.
One of the easiest ways to get lots of info is to get the MovieFactory Demo
and drop the files in to it , and ask for clip info.
Then run Gspot on them and AVI codec
The ultimate goal is to identify all of it and convert it to a common format,
Tell us what you find out and more help will be forthcoming. -
I did not know the UK had colonised UranusOriginally Posted by FOO
Remove multiple tracks from multiple MKV files
By accoutabc in forum Video ConversionReplies: 3Last Post: 7th Aug 2011, 12:50 -
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 19:34 -
turning multiple avi files to dvd
By videodude1966 in forum Video ConversionReplies: 1Last Post: 23rd Dec 2010, 19:32 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 09:27 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 03:28
