  1. when i am converting an avi with tmpgenc, i get a black line across the page.
    what causes this problem? is it interlacred or something???
    thanks
  2. Did you check if the source had the black line ?
    Otherwise it might be a codec problem.
  3. no the source was fine!
    how could a codec cause this problem?
  4. It is possible that the codec, which is the middle ring in a chain of encoding (your file -> codec -> TMPGEnc -> Output file) gives this lines because it can not convert it to the needed format.
    Try determine the codec using GSpot and install the latest version of that codec.
