I am very new to this conversion.I have some AVI files and i tried them to convert them using TMPGEnc[/url] and some other tools but with all it converts only for 1 min and then only audio is converted not video.So Please can some help me to how to convert.Please!!!![]()
What you need to do is first to determine the codec of your AVI file using GSpot.
Then, if it is divx, it seems problem is in the codec version. If you have the older codec then the file has, you will be getting this freezing after some time. Try to install the latest Divx codec. -
Did you scan for bad frames with Virtualdub?
Sound lost after conversion mpeg to avi
By maclinux in forum Newbie / General discussionsReplies: 1Last Post: 19th Dec 2008, 13:47 -
Quick .avi Conversion to MPEG-2 ?
By christopheramos in forum Video ConversionReplies: 7Last Post: 5th Feb 2008, 18:42 -
Conversion from asf files to avi or mpeg
By Jescal in forum Video ConversionReplies: 1Last Post: 23rd Jan 2008, 16:37 -
AVI to MPEG conversion and DVD burning
By mc-help in forum Video ConversionReplies: 2Last Post: 5th Jan 2008, 16:08 -
No sound conversion MPEG-TS to .avi
By oli60 in forum ffmpegX general discussionReplies: 2Last Post: 22nd Oct 2007, 00:49
