Hi everyone
Sorry if this question has been asked loads of times before.
Downloaded a movie (DivX) from newsgroups, and followed the guide in this forum to encode and burn it.
Used VirtualDub, TMPGEnc and then VCDEasy, but picture feeezes every 10-15 seconds or so, just slightly, but enough to put you off watching.
Works fine on PC. Also tried a few different CD brands, but both the same.
Reading on the forums it may be a bitrate problem. I selected VCD (PAL) from TMPGEnc and the below was set:
Video-CD PAL (MPEG-1 352x288 25fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
Had a look in the settings for TMPGEnc, but can only change the birate for SVCD. Is it worth going down this route instead.
Cheers
Pie
If the DIVX source is fine, the problem is in your encoded file.
This problem often occur when you convert PAL video into the VCD in TMPGEnc and deals with frames per second.
I've had this problem before. What I did was I used VirtualDub to frameserve the divx into TMPGEnc and encode to VCD.
Try to use this VirtualDub frameserve guide (do not change bitrate, just frameserve it strait to TMPGEnc bec. you convert from PAL -> PAL). and that should get rid of jumpy playback. -
Hi
Tried frameserving it straight from virtual dub to tmpgenc, but it is still really jumpy as before.
Any other ideas?
pie
Forum is 'Jumpy'
By olyteddy in forum FeedbackReplies: 6Last Post: 18th Nov 2010, 23:09 -
DVD is jumpy after conversion
By RebelUK in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 29th Jul 2010, 14:04 -
Avi to dvd jumpy..?
By Mozzy31 in forum Authoring (DVD)Replies: 7Last Post: 7th Feb 2010, 05:05 -
Jumpy jerky mp4's
By zinc in forum Software PlayingReplies: 3Last Post: 13th Dec 2008, 16:15 -
Jumpy DVD ?
By Dash1 in forum Newbie / General discussionsReplies: 7Last Post: 2nd Jun 2007, 15:53
