I am having a problem with numerous DiVX/XviD files which when I try to encode them with tmpegenc the output run time is double the expected time.
Tmpegenc version: v2.59.47.155
The DivX files are version 5.0.
What other info would be useful?
Any tips would be greatly appreciated.
Open you divx in virtualdub, if you get a warning about VBR audio, thats your problem, Tmpgenc doesn't like it.
There are two possible solutions.
1) Convert the audio to uncompressed wav using virtualdub or Goldwave. Use this wav file as the audio source when you encode.
2) Use Tmpgenc's source range feature to tell it stop encoding at the appropriate time. -
Thank you very much I will try that this evening. I know one of the files gives me that exact error.
Total running time
By mrcoolekin in forum Authoring (DVD)Replies: 26Last Post: 15th May 2009, 01:38 -
Maximum running time
By biged670 in forum Newbie / General discussionsReplies: 4Last Post: 17th Feb 2009, 17:39 -
DGPulldown and running time?
By ecc in forum Video ConversionReplies: 1Last Post: 19th Dec 2007, 03:23 -
**Help! Need to burn a DVD and running out of time to do it!**
By catdrummond in forum Newbie / General discussionsReplies: 1Last Post: 19th Oct 2007, 07:53 -
Accurate running time of various Media
By neftv in forum MediaReplies: 1Last Post: 17th Jul 2007, 17:53
