I've downloaded MPG files (like world trade center footage) and want to burn it to a CD. How do I accomplish this. I have tried with the Easy CD Creator but it say's , the file contains no audio files. I am no computer guru whatsoever so PLEASE, explain this in detail so I can understand.
You can only use an MPEG of particular specifications to make a VCD. It is unlikely that your downloaded MPEG fits those specifications (read What Is VCD on the left hand corner for more info).
You can re-encode your MPEG to VCD specs using TMPGEnc.
Regards.
Michael Tam
w: Morsels of Evidence -
you can also use nero ver 5524 to burn a vcd and let it do the encoding for you...
U need to load them in TMPGenc, if the video (file) format is supported, and use a VCD Template to creat a VCD that stands by the standards of VCD so u can play them in a stand alone dvd player, Encoding them isnt hard or (if u have a VERY FAST processor like a 1.4GHz Tbird or P4, nothing over 2.5 hours to encode.
_________________
Computers
<font size=-1>[ This Message was edited by: Chris X on 2001-10-07 01:38:54 ]</font>
<font size=-1>[ This Message was edited by: Chris X on 2001-10-07 01:39:37 ]</font>
mpg won't stream until the entire thing is downloaded.
By flycast in forum Video Streaming DownloadingReplies: 1Last Post: 19th Dec 2009, 23:23 -
How to make flashes play normally in VCD?
By blair in forum Video ConversionReplies: 5Last Post: 20th Oct 2009, 06:14 -
How to make a VCD/SVCD with CD Audio (CDDA)
By Baldrick in forum User guidesReplies: 74Last Post: 24th Dec 2007, 19:37 -
Easy Freeware to make DVDs out of mpg and avi files?
By gail22 in forum Authoring (DVD)Replies: 13Last Post: 15th Oct 2007, 19:31 -
How to make an autorun VCD in English please!
By jimiir in forum Authoring (VCD/SVCD)Replies: 10Last Post: 8th Aug 2007, 23:56
