I've been encoding DivX movies to DVD+R at 23.97fps. I have been reading about the 3:2 pulldown ever since DVD-Lab prompted me to add these flags when I imported a 23.97 video asset. I have also read it's better to encode at the same fps as the source to maintain the audio synch. If I use the 3:2 pulldown, do I have to do anything to the audio as well - such as using the OTA conversion in BeSweet? Also, is it better to add the pulldown flags in TMPGenc during encoding or let DVD-Lab do it?
No, you don't have to touch the audio. Yes keeping it 23.976fps is definitely the best thing to do. Most NTSC DVDs are in fact encoded at 23.976fps and "pulled down" to 29.97fps, its the preferred way to store NTSC film digitally.
I've never used DVD-Lab so I have no idea how well its 3:2 pulldown function works. I've used TMPGenc's and it seems to work fine though some people have complained that some authoring programs gave them errors. All I can say is that using pulldown.exe is probably your safest bet, though DVD-Lab and TMPGenc will probably work just as well too. -
Only check the one on the Video tab under encode mode. The 3:2 pulldown filter is for hard telecining 23.976fps to 29.97fps. Basically, it actually creates the additional frames and encodes them into the picture, rather than simply inserting the flags to tell the DVD decoder to do it on the fly.
Got it, thanks again. I also downloaded pulldown.exe, which looks pretty easy. I'll give that a try too.
I've been wondering about thisMost NTSC DVDs are in fact encoded at 23.976fps and "pulled down" to 29.97fps, its the preferred way to store NTSC film digitally
23.976fps was never an issue before (doing vcd's)
But since burning to dvd need to be 29.97fps or Pal, I was getting confused, so (by trial & error) I put the file through TMPGenc's wizard and chose NTSC 29.97fps even though my file states 23.976fps (AVIcodec) and the file played perfect - not what I was expecting!
Cheers adam At least thats cleared up my confusion
or has it? -
Its really no different between DVDs and VCDs, because ultimately its the regional format that you are locked into that decides what fps you can use. NTSC tv's run at 29.97fps...period. Whether you are making a VCD or DVD its going to have to play back at that speed on an NTSC tv. VCDs don't support pulldown flags, but dvd players are supposed to autotelecine them if they are 23.976fps. DVDs do support pulldown flags, so whenever you encode at 23.976fps you have to apply them in order to be compliant and in order for the DVD player to do the telecine.
I assume TMPGenc's DVD wizard will encode a 23.976fps source in ntscfilm with pulldown flags if encoding to DVD. If so, your method is fine. The problem with wizards though is that you don't always know what is going on. A good test to see whether your footage was encoded correctly would be to preview it in dvdavi. If it says %100 film then its correct, if it says NTSC then TMPGenc just telecined the movie instead of applying pulldown flags.
[MKV] 25fps to 23.976fps? Tried and failed. Help!
By lag in forum Newbie / General discussionsReplies: 15Last Post: 20th Aug 2014, 12:27 -
24fps video with 23.976fps audio
By brijazz in forum Video ConversionReplies: 1Last Post: 9th May 2010, 07:43 -
NTSC HDTV is usually broadcast at 23.976fps, yes?
By Gew in forum Newbie / General discussionsReplies: 38Last Post: 21st Feb 2010, 18:56 -
25fps to 23.976fps
By Charmer in forum AudioReplies: 19Last Post: 8th Aug 2009, 10:41 -
converting 25fps to 23.976fps
By pannivas in forum AudioReplies: 1Last Post: 3rd Aug 2007, 16:49
