  1. I know this has been on the forum before and I have tried Virtual Dub MP3 freeze which says there are no bad frames, and I have tried moving the Direct Show Multimedia to a priority of 4 but I still get to 37% encoding before it says "index of scan line is out of range (240).
    Does anyone have any other suggestions please to rectify this.
  2. Can anyone help with this one please?
    Mar 2003
    Uranus
    If the flie reads all the way through in Vdub, just
    Frameserve it to TMPGenc from there. That way TMPGenc
    only gets good uncompressed video.
  4. Thanks, I will try that.
  5. I have tried to framserve it to TMPgenc without success.
    I have used the guide, but when it gets to framserver mode, nothing happens.
    Also I have tried to open it in TMPgenc but it says it is unsupported.
    Any tips for me please.
    Mar 2003
    Uranus
    Did you open the file in Vdub ?
    Does it play ?
    Did you File->Start Frameserver ? and name the output file.vdr ?
    Did you open TMPGenc and then open file.vdr ?
    Did that work ?
    did you set environmental settings in TMPGenc as per the guide
    did you run auxsetup in the vdub folder ?
  7. Yes, I have done all of the above.
    Mar 2003
    Uranus
    I guess you read this
    https://www.videohelp.com/virtualdubframeserve.htm
    and check the link at the very bottom. There are some
    answers for various problems.
    I never had a problem and use it all the time
