I was told that I could use Virtual VCR as I would a normal VCR for doing TIMED RECORDING but I see NO settings for such a purpose. Can you help with this OR is there another cheap or free program that I can use to do timed ANALOG capture ? Thanks.
Try VirtualDUBVCR, from here....
http://www.virtualdub.net/zip/VirtualDub1492VCR+SYNC.zip
It's free and you can set it to record just like a VCR, the only thing i haven't figured out yet is why it won't 2 or more programmes when the timer is set. -
I use Virtual VCR for scheduled / timed captures all the time. You use the Windows task scheduler. Its all explained here: http://www.digtv.ws/html/virtualvcr/general.php.
Help please:Virtual VCR crashes on startup
By cgarai in forum Capturing and VCRReplies: 10Last Post: 11th Apr 2012, 15:53 -
Is there a way to do a timed recording for the hauppage hdpvr 1212?
By yoda313 in forum Capturing and VCRReplies: 4Last Post: 13th Mar 2011, 19:48 -
Please help: Virtual VCR not detecting Audio Device
By cnfcnf in forum Capturing and VCRReplies: 6Last Post: 30th Jan 2011, 13:17 -
Recording in VCR Mode
By mapmaker in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Oct 2008, 19:23 -
Timed USB Mpeg4 Grabber recording. Is this possible?
By GLOpro in forum Capturing and VCRReplies: 2Last Post: 5th Jul 2007, 19:21
