  1. I am having a bit of a problem using VCD Imager Easy v1.0.1
    I am running a dual boot system - Win98SE & Win2k. The program works like a charm under Windows98SE. However, when I load the program under Windows 2000, it says "CDrDao.exe scanbus execution failed." It will not detect my cd burner.
    I have created SVCD's with no problems whatsoever while working under Windows98SE. What gives?
    Any help or suggestions would be greatly appreciated.
    john-john
  2. Perhaps CDRDAO doesn't recognise your burner.
    Search for CDRDAO with Google and go to the official site for more info.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  3. That seems strange. It recognizes my burner in Win98SE.
    I'll see what I find. Anyone else with any other advice would be appreciated.
    john-john
  4. I think what your problem might be is missing ASPI drivers in Windows 2000 -- ASPI allows communication between CD recording software and CD recorders. I have Windows 98 and was getting the same error message, but in my case the ASPI drivers were not installed/working correctly.
    Check out aspichk.exe (available at ftp://ftp.adaptec.com/software_pc/aspi/aspichk.exe) -- it is a tool from Adaptec which reports the version of the ASPI layer that is installed on your computer and makes sure it is working correctly. I was then able to use ForceAspi 1.7 (d/l'ed from doom9.org) which allowed me to install the latest ASPI drivers on my computer (works on NT, 2000, ME, 9x). Worked like a charm!
    Thor
    <font size=-1>[ This Message was edited by: Thor on 2001-10-09 19:58:53 ]</font>
  5. Thanks. I will be sure to look into that asap. Wish me luck
    Thanks again!
    john-john
  6. Thor
    Thanks for the advice. I downloaded the tools that you indicated and you were right, they were not being properly detected. I then downloaded the appropriate software and it now works like a charm.
    Thanks again for your help!
    john-john
  7. I actually get a similar problem on Windows ME. Same error. But in my case it is sporadic. Half of the time it doesn't work, and half of the time it works fine. If I can start up VCD Imager Easy without the error you got, then it works great. If I get the error, though, I can still use VCD Imager Easy, but I can't use the CDRao software to burn with. Often, it takes a reboot of my machine, and then it will work. Sometimes I just have to exit the software, start something else, and then restart VCD Imager Easy.
    Aug 2001
    Compuball
    I'm brand new to SVCD's and I was wondering if CDRDAO came with VCD Imager Easy? Do I download both or does VCD Imager Easy have it included?
