I hate to ask what a good disk is, buuut
I looked over many media sites, any that have a compatability chart eithr do not list this sd-r5002 drive or shows the disk I am looking at as only 1x if the drive is listed!
Do you have this drive, are you burning 2x, what disk? WHats the failure rate on them for you?
I am looking for good disks, 50 or 100 packs at abut $1-$1.30 each. Maybe some printables.
If you have this drive, did you have to do anything to make it burn 2x? Firmware update? Certain ide conector like SLave or master on ide 1 or 2?
I am getting good results with lead data (princo) at 1x I bought in March, but I'd like to get burning at 2x like it claims!
Results 1 to 1 of 1
Burn large MKV file onto several DVD-R disks
By fazza8 in forum Authoring (Blu-ray)Replies: 3Last Post: 11th Jan 2009, 06:28 -
Toshiba RD-XS35 won't play some disks
By inferno7 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 12th May 2008, 13:18 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 10:24 -
What burner should i use to burn double layer disks
By Trident5 in forum DVD & Blu-ray WritersReplies: 8Last Post: 25th Sep 2007, 05:51 -
Toshiba A2 and DVD-R disks
By Prot in forum DVD & Blu-ray PlayersReplies: 4Last Post: 29th Jul 2007, 18:28
