I am using DVD-Lab and I have 2 x titles, each with three VOBs.
VTS_01_1.vob
VTS_01_2.vob
VTS_01_3.vob
VTS_02_1.vob
VTS_02_2.vob
VTS_02_3.vob
When I create the connections in DVD-Lab, how should I do this so that the VOBs follow in the correct sequence when playing back?
Do I simply add one movie frame for each vob, link each frame sequentially and return to the menu at the end? If so will there be any delay in switching between VOBs at playback?
Pete
Yes, you can do this, but if it were me I'd have DVDLab demux the VOBs (you select the first one in each movie and DVDLab will convert the remainder into one m2v with audio tracks). It takes a tiny bit of time (say five minutes or so per VOB series) but will make playback much smoother.Originally Posted by dvdpete"Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang
Thanks, that did the trick.
But 5 mins? wow, how fast is your PC? My HDD is getting full so I guess that was the problem and delay.
Thanks again for your help.
Pete -
Yes, you want to have plenty of free, unfragmented hard drive (I have one separate 160gb hard drive just for video).
But I'm only running a P4 2.4gz, with XP Pro. I don't consider it particularly fast nowadays."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang
Convert non-compliant VOBs to "good VOBs"
By pmolson in forum Video ConversionReplies: 3Last Post: 24th Oct 2008, 11:52 -
DVD Lab Pro - Using VOBs, Audio Problems
By teacozie in forum Authoring (DVD)Replies: 5Last Post: 24th Sep 2008, 02:12 -
Create DVD from several VOBs ?
By flash70 in forum DVD RippingReplies: 3Last Post: 8th Jun 2008, 10:51 -
Missing vobs on DVD
By stencil in forum Newbie / General discussionsReplies: 4Last Post: 13th May 2008, 00:17 -
How to Fit five VOBs onto one DVD?
By DeEp34 in forum Newbie / General discussionsReplies: 10Last Post: 14th Jul 2007, 20:42
