I have a movie to encode that is 75 minutes long. Can I fit this onto one cd-r using the kvcd settings?
I have tried to work this one out but the bitrates I get always turn red in the window (indicating they are too low)
Does anyone know the correct settings for this?
cheers
markusb
You can store on a 700MB CDR media about:
VCD Preset: 80 min of video at near-VHS quality
CVD Preset: 52 min of video at near-SVHS quality
SVCD Preset: 45 min of video at near-DVD quality
KSVCD Preset: 63 min of video at near-SVCD quality
KVCD Preset: 108 min of video at near-VCD quality
You can store on a 4GB DVD media about:
DVD-hi Preset: 145 minutes of video at DVD quality
DVD-lo Preset: 4 hours and 10 min of video at near SVCD quality
KDVD Preset: 5 hours of video at near SVCD quality
The bitrate coloring currently assumes normal Q Matrix is always used, so you can ignore it for KVCD.
The picture size is correct. You should see it on a TV, and the aspect will be correct. About muxing, there are indeed situations where the muxing can fail. Try to mux again with the "Mux as.." tool, using either XVCD or generic mpeg-1 profiles. I'll also improve the muxer in 0.0.8d.
MPG to KVCD HELP
By G33333 in forum Video ConversionReplies: 12Last Post: 25th Dec 2007, 06:00 -
KVCD
By Bat21UK in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2007, 15:31 -
KVCD- to DVD question...
By marklight in forum ffmpegX general discussionReplies: 3Last Post: 12th Jun 2007, 00:30 -
Xvid to KVCD
By mjaeson in forum Video ConversionReplies: 8Last Post: 25th May 2007, 20:05 -
KVCD to DVD
By buttzilla in forum Video ConversionReplies: 2Last Post: 6th May 2007, 08:01
