I've looked thru the archives on here. but didn't note anything definitive, so i thought I'd ask.
I've got some footage (it's stock footage for a project, 30 second piece) that is 4:3 video.
I'd like to convert it to letter box/16:9, as I think it would give it a nice look/feel.
What is the best way to go about this?
The tools I've got to use are: adobe after effects, combustion 2, adobe 6.5, vegas 4.0 and tmpgenc.
Actually, I suppose just letter boxing it would be fine, since the cable stations it'll be played at still broadcast in 4:3.. so going to a true 16:9 probably isn't needed.
Can I just mask the top/bottom? and does anyone know the proper number of pixels the top and bottom mask needs to be?
I appreciate the help.
-d
I don't understand why you want to do what you describe.
Letterboxing is a technique to make the whole width of a widescreen movie visible. Since the width is too much for the aspect ratio of the normal TV, black bars are displayed on top and bottom.
With the 4:3 video, converting it to widescreen means you either stretch it - in which case the picture becomes distorted, or you crop lines from the top and the bottom - losing content - and resize it - generating artifacts.
With 4:3 source video, all you can do on a widescreen TV is allow the TV to generate vertical bars to the left and right.The more I learn, the more I come to realize how little it is I know. -
I have a widescreen tv and have used tmpg.to convert 4:3 to 16:9.
Set the source to 16:9 and the output to 16:9 and it worked ok.I also decided that the tv does a good strech on the 4:3 rendered video,so that's what i use.I'm sure that if the source is 4:3,then all you are doing is adding black bars on a 4:3 tv and stretching the source video.
I don't see an advantage to converting 4:3 material to 16:9 as a widescreen tv will do that for you.There is no more material on the video to access when converting to widescreen.
Bradbmiller,ont.canada
How to convert FLV videos and resize them to convert them to AVI
By zikegi in forum Video ConversionReplies: 2Last Post: 17th Sep 2011, 23:06 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 05:44 -
To convert or not to convert a pal dvd
By nls8520 in forum Video ConversionReplies: 1Last Post: 22nd Jun 2010, 01:35
