Im looking at getting a good dvd player that will play most blank dvds at the best price. If anyone has any opinions help me out?
i have a toshiba sd-k620 i paid $60 at costco and plays:dvd-r,dvd-rw,dvd+r,
dvd+rw,vcd,svcd,mp3,wmp,jgp. -
If looking for a relatively cheap DVD player with quality DVD!!! playback, I'd recommend Panasonic S35. Thou when playing VCD/SVCD, the quality may not be the best.
FYI: since I got a DVD burner, I don't burn VCDs or SVCDs no more. A good quality VCD or SVCD formatted movie will take some time to make (encoding and stuff) and will be of lesser quality than if in DVD format. Then again, you have to put in on several CD-Rs and then price of the CD-Rs used for 1 movie is comparable with price of a DVD +/-R disk you can put the movie on. You'll have to change the disks too, if on several CD-Rs.
Need codes to convert Australian DVD player into a multi region DVD player
By Seajacb123 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Oct 2010, 01:00 -
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 12:55 -
Subs work on PC/VLC Player...but don't show up on dvd player
By bgart13 in forum SubtitleReplies: 9Last Post: 22nd Aug 2009, 18:06 -
my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
By LEONESVIZZERO in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Apr 2008, 09:15 -
How Can I Convert Real Player Video Files To Make Them DVD Player Compatabl
By Lennoxtown in forum Video ConversionReplies: 8Last Post: 17th Oct 2007, 06:05
