I have a PAL DVD that I wanted to convert to NTSC so I can play it on my Sony DVP-S560D...Any help???
Results 1 to 12 of 12
My honest answer is to buy a $40 player that plays both PAL and NTSC. Mintek, Apex and Cyberhome are very nice players for this, just to name a few. In the long-haul, especially if you want to get more PAL in the future, is to do this. Converting take a long time, and does not always give flawless results.
Many NTSC players also play PAL, just not Region 2/4 discs. Maybe a DVD-RW region-free copy will work on your Sony? In fact, if the Sony book does not explicitly exclude PAL, it probably will play it.Want my help? Ask here! (not via PM!)
Thanks for the info but this is the only PAL DVD I have so I don't really want to buy a new player. Also, I wanted this DVD to be compatible when I brought it over friends house to watch. So, any detailed guides to convert to NTSC DVD would be awesome. Thanks!!
Have you looked in the guides section of this site???
https://www.videohelp.com/guides.php?howtoselect=4;41
Particulary the last guide, Standards Conversion shows how to convert DVD PAL to DVD NTSC.Open WIDE for Chunky!!! -
Hello
Here is pretty much all the INFO you need to know:
1.) http://www.geocities.com/xesdeeni2001/StandardsConversion/
2.) https://www.videohelp.com/forum/viewtopic.php?t=160433&highlight=
Good Luck !!!
Woah..26 hrs to reencode to NTSC using TEPGEnc with my AMD 2000+ or 21 hrs using my 2800+ Damnnnnnnn
Ok..I reencoded it using high quality and 2 pass VBR. The original PAL DVD was 4.3 gigs...Now after reencoding it to NTSC, the file sis is 7.6 gigs!!! How come?
OK... When I try to open my newly created .mpg in TMPEGnc it says File "xxx" cannot open or unsupported...UGH!!
I opened it with TMPEGnc once and haven't been able to open it since... -
Well the size of the newly created NTSC MPEG-2 depends on the running time of the PAL movie and the bitrate you used.Originally Posted by Daveyd
First you need to convert the PAL running time to NTSC (assuming you are using a method that slows down the 25fps to 23.976fps). This is easy. For example let us say the PAL movie is 115 minutes.
115 * 25 / 23.976 = 120 (approximately)
So simply use a bitrate calculator and find out what your bitrate should be.
This is no different than any type of MPEG-2 encoding.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
What's the easiest way to convert a PAL DVD to NTSC?
By snafubaby in forum Video ConversionReplies: 3Last Post: 26th Mar 2012, 21:21 -
convert pal dvd to ntsc, but different
By atomicrabbit in forum EditingReplies: 5Last Post: 12th Jan 2008, 04:48 -
Convert PAL 16x9 DVD to NTSC DVD w/ Procoder - Less Image-More Borders Why?
By tubularusa in forum DVD RippingReplies: 15Last Post: 5th Aug 2007, 02:26 -
How to convert PAL DVD to NTSC?
By tomterrifk in forum Newbie / General discussionsReplies: 3Last Post: 18th Jul 2007, 16:35
