Hi,
Is this conversion a possibility in FFMPEGX? If it is, please tell me the steps to take to do this conversion. If not, are there any other options I have in encoding to VCD from this format on a Mac?
Thanks,
wolfwood87
Results 1 to 11 of 11
Hi Major,
I have the file but I am not sure how to:
1. Cut a test clip of the file.
2. Get this test file to you. Do you have an iDisk? If you do I could upload it to that with your permission. I don't have a website or any webspace to my knowledge. I could send it to you via iChat if you have the program. I don't mind how the transfer takes place, but I am not sure how to do it.
Thank you for your reply!
Wolfwood87
AnonymousGuest
Tried to go from OGM -> VCD:
Info for file from vlan:
Stream 1
Type: Picture
Codec: DX50
Frame-Rate: 25.000000
Bit-ammount: 24
width: 512
height: 288
Stream 2
Type: Sound
Codec: Vorbis
Data-/symbolrate: 48000.000000
Channels: 2
Bit-rate: 112001
Vorbis Comment:
LWING_GAIN: 01.00
Errormsg from ffmpegx:
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
Wed Sep 17 15:04:49 CEST 2003
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
/Volumes/xxx/xxx/xxx/xxx.ogm: Unknown format
**ERROR: [yuvscaler] Could'nt read YUV4MPEG header!
**ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!
I had the same results as Schlumpf when I tried the OGM to VCD conversion in FFMPEGX v0.0.8b Do you still want to try to work with this file Major? If yes, then I am still not sure how to cut a test clip of my file. It would be great if I could turn this movie into a VCD and watch it on my DVD player....
Thanks to everyone,
Wolfwood87
AnonymousGuest
Yup, same for me: No way to split it. Could send the whole 701,1 MB file though
No problem, I'm on a fast line...
I was able to convert your .ogm file to SVCD and CVD. Unfortunately VCD conversion is not possible for now. I proceeded as follows:
- Open the .ogm file
- Select CVD (or SVCD) quick preset
- Enable the "Decode with mplayer" option
- Select audio track = 1
AnonymousGuest
Excuxe me, I tried to encode a few ogm files, but even using Major's method, I still can't do a proper download: The program tells me that the file I want to encode cannot be found
.ogm file
By d_animality in forum Authoring (DVD)Replies: 2Last Post: 29th Aug 2011, 08:19 -
How to Convert OGM!?!
By SamohAD in forum Video ConversionReplies: 6Last Post: 19th Mar 2009, 18:42 -
.OGM help
By Moparbear in forum Video ConversionReplies: 2Last Post: 3rd Mar 2008, 19:08 -
OGM remuxer?
By Colmino in forum Video ConversionReplies: 1Last Post: 25th Nov 2007, 13:27 -
Question regarding .ogm
By Justin Wade in forum Newbie / General discussionsReplies: 3Last Post: 17th Sep 2007, 12:39
