    Anybody know where i can find some cool computer generated mpegs to use as menu background? would like them to be in a high quality format to use with DVDs.
    syoung
    Aug 2003
    Des Moines, Iowa USA
    Digital Juice seems to have some very nice high quality motion backgrounds. At first glance they seem VERY expensive, as you must buy them in packs for some significant cash.
    40± for $250
    120± for $500
    400± for $1000
    800± for $1500
    Looks like these are intended for 'professional' use more than anything, as I doubt the average person would have a need for 800 motion backgrounds.
    If you look at the cost per background ($2 - $6 depending on how many you buy), for the quality you're getting this doesn't seem to be too bad...just wish you could buy them individually. Of course then they would be more expensive per background
    Open WIDE for Chunky!!!
    Apr 2002
    The State of Frustration
    I have to go with Holistic on this one. Main Concept gives their loops away for free at five clips a month, or you can buy all 100 for $20.00. Twenty cents a piece? Where's that calculator, I want to do the math...
    Hello.
