I have a few video files off the net and i want to view them on my TV.
I use VirtualDub and that tells me that most of them are 29,970 fps which i think means that they are ntsc.
how do i find out other info like if they are MPG2 or 1 or DIVX...etc
what is the best way to get them onto CD or DVD without re encoding and loose more quality.
GspotOriginally Posted by Sifaga
Unless they are already (S)VCD or DVD compliant mpegs, you will have to re-encode if you want them to play in a standalone player. And yes, this will reduce quality. If you choose a format that has the potential for better quality than your source material (DVD perhaps), the quality loss will be minimal. If you go to VCD, and have super quality source material, the quality loss wil be quite noticeable. Its up to you.Originally Posted by Sifaga
Read a few of the guides on how to achieve what you want.
wont recognise camera connected
By sarah1 in forum Newbie / General discussionsReplies: 4Last Post: 6th Apr 2010, 07:09 -
DVDFab won't recognise DVD
By audax in forum Authoring (DVD)Replies: 3Last Post: 3rd Jan 2010, 01:16 -
Anyone recognise this noise?
By DaveQB in forum Capturing and VCRReplies: 26Last Post: 20th Oct 2009, 11:49 -
My PC will not recognise my MP3- It was fine for 8 months??!
By jenniewb in forum ComputerReplies: 8Last Post: 28th Dec 2008, 12:30 -
OS won't recognise harddrives
By mysts in forum ComputerReplies: 6Last Post: 9th Mar 2008, 14:57
