Ok I'm just the basic dvd ripper guy
this time I decided to rip terminator 2
Opened up tmpge loaded the files I got from dvd2avi
loaded the tibro vcd template
played the movie back and its showing double frames
I think its probably that the movie is ntsc film
I just used the basic tibro vcd template which is ntsc
Think that might be the problem or it might be something else
thanks for reading is guys
Peace
Not sure what you mean by "double frames" but you could be seeing interlacing from the telecining of the source film.
IF that's what happening here's what you do. Run DVD2AVI again, and enable force film. Then encode the movie w/ the NTSC film template.
Simple DVD editing and encoding software? (Scene release)
By djkilla in forum Authoring (DVD)Replies: 4Last Post: 18th Nov 2011, 08:48 -
A simple question on Two passes Xvid Encoding,using GordianKnot(not autoGk)
By avengerevenge in forum Newbie / General discussionsReplies: 2Last Post: 26th Jun 2010, 07:46 -
Can I do a simple fade in/out on clips pulled from BD without re-encoding?
By Dan Miller in forum EditingReplies: 4Last Post: 7th Jun 2010, 00:31 -
mic input -realtime denoise -> sent as input to dragon naturally speakin
By logicom in forum AudioReplies: 0Last Post: 27th Sep 2009, 11:46 -
The best simple H264 Encoding App ?????
By Arlo in forum DVD RippingReplies: 3Last Post: 10th Dec 2008, 14:18
