Results 1 to 11 of 11
  1. Hi, i have a mpeg 2 file og 3 gb and i want to watch it on my dvd but i can not convert it to vcd or svcd obviously, what can i do? do i have to encode it?, please help.
    thank you.
    i have a JVC 523gd player-
    Mar 2003
    Uranus
    I guess you don't have a DVD burner ?
    You could cut it up and put it on several SVCDs
  3. Yes, i have a pioner ao5.
  4. Then why not just make it into a DVD instead of a VCD or SVCD? You'll even get better compatibility with other players as a bonus. A DVD can hold over 4gigs, you could even put another short film on the same disk. Its a Win-Win cenario. And everyone likes those
    "A beginning is the time for taking the most delicate care that the balances are correct."
    - Frank Herbert, Dune
  5. ok, but how do i do that? with nero? how?, please, thank you.
  6. Solarjetman????
    Mar 2003
    Uranus
    It's illegal to tell people to shoot themselves, so I can't do that
    How about reading the Nero help ?
  8. Well, if the mpeg file is in a valid format...
    https://www.videohelp.com/dvd#tech
    Then all you need to do is use a DVD authoring program such as TMPGEnc DVD Author to author the disk...
    https://www.videohelp.com/forum/userguides/172123.php
    Although TMPGEnc DVD Author is not free, there is a trial period on it. InfoEdit is free, but it is very limited in its capacities...
    https://www.videohelp.com/forum/userguides/120013.php
    Hope that helps.
  9. Well.... thank you, i thought it wouldn´t b so difficult to tell.
    thabks anyway.
  10. Originally Posted by lancerx
    so difficult to tell what? The process is quite simple, even though i sounds a little complicated. If you don't want any fancy menus, it it little more than telling the DVD authoring program where the mpegs are and saying "make me a DVD".
  11. Thanks solarjetman, i took my chances with Ulead movie factory and made a dvd with the fancy meny and it worked, i'll try with Tmpgenc later.
