I have the Sony DRU 500A recorder. sometimes, when I' m trying to rip a movie the recorder makes a ticking noise and the ripping stops. How can I solve the problem ?
Is the disc scratched in any way? What do you use to rip? DVDDecrypter tells you if it encounters read errors. Do you get any software error?
I have one too, I think its a poor DVD reader. Little minor problems with a DVD can cause the DRU500A to croak and die. I've got DVDs that the DRU500A cant read, but that other computers I have access to can read fine, along with standalone DVD players.
Im going to buy one of those cheap Lite-on DVD drives, and keep the sony for burning, which it does a great job at. Besides 2x read gets real old real fast... or real slow....
If you have the same problems I did, it generates hardware read errors.Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
I also own a Sony DRU500A, but I never use it for ripping. I use my Liteon 16x for ripping. I have found the hard way that DVDDecryptor tends to tank if it encounters read errors that require a retry. Once read errors show in the log for DVDDecryptor, you need to kill DVDDecryptor. Remove the DVD from the drive, carefully clean off any smears or smudges or fingerprints, and then start again from the beginning.
I have seen DVDDecryptor hang up, pretending to read but in reality doing nothing. Kill the program, clean the disk, start over.
/Sony DRU-190A problem
By Quadzilla in forum DVD & Blu-ray WritersReplies: 22Last Post: 7th May 2009, 14:10 -
Firewire External Enclosure for Sony DRU-500A. Help choose..
By donpedro in forum DVD & Blu-ray WritersReplies: 79Last Post: 25th May 2008, 11:52 -
Sony DRU 800A Problems burning??
By khronos000 in forum Newbie / General discussionsReplies: 4Last Post: 17th Sep 2007, 17:40 -
Sony DRU-810A question...
By bamabluebird in forum DVD & Blu-ray WritersReplies: 4Last Post: 10th Jul 2007, 10:21 -
Sony DVD RW DRU-830A
By bjswitz in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th May 2007, 08:41
