I have several MP3 files that I would like to compile to a CD. However, as is the case with DVDs, each of the MP3's seem to have a different volume level. It would be extremely irritating for each of the songs to skip in volume level while listening. I would like to have all the songs on the DVD be about the same volume level. How can I burn the DVD or re-encode the MP3's so that they all have an approximate consistant volume level>
Patrick
I usually use dbPowerAmp (http://www.dbpoweramp.com/) tool, its free. But the problem is, it reencodes all the files.
If you use Nero Express, it has an option to normalize audio files (after all files have been added for burning). If you look, it's in the bottom right of the window - after checking this box, it will take a few extra minutes to normalize the files, then automatically begin burning.
Ethernet (n): something used to catch the etherbunny
What are the differences in these 2 BR Burners?
By golfnut in forum DVD & Blu-ray WritersReplies: 27Last Post: 23rd Apr 2012, 19:14 -
raise volume for sections of mp3?
By charlieship in forum AudioReplies: 19Last Post: 29th Sep 2011, 17:29 -
Differences between these two files..
By dhr in forum Software PlayingReplies: 4Last Post: 13th Feb 2011, 21:35 -
Sony trv 18 no internal speaker volume, no headphone volume
By websbymark in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 5th Oct 2009, 12:39 -
Player Differences
By Xandal in forum Newbie / General discussionsReplies: 5Last Post: 21st Jan 2008, 15:43
