Hello all, this is my first post.
I have recently leaned (the hard way) that there is an Aspect Ratio tag, or DAR Tag, inserted into a DVD mpeg2 stream during it's creation, (in my case, with TMPGEnc.). Unfortunately, I didn't know this, so changed the output seeting of TMPGenc to encode so taht it looked right on the PC. It was encoding in 720x576, and at a 16:9 ratio, leaving black bars (as I wanted) at top and bottom. But, I had selected a widescreen template, so, as far as i understand, this meant that it associated a 16:9 tag with this 16:9 film, in essence squashing it vertically again, after it had already been made 16:9. It looks fine on the pc, but in the player, looks squashed. I realise my mistake and I'm encoding my second movie te proper way.
But, I want to be able to change the encoded tag of the first one so that it looks right in my DVD player ( I will need to change it froma 16:9 to a 4:3) without having to re-encode the entire film, which takes about 3 and a half hours. Please help me, I hope there is a way.
Jonathan.
yes - you can do this with pulldown.exe -- its in the tools section .. get the gui for it also .. just make sure you check off "do not perform pulldown" and just check the DAR change you want to make . there is no re-encoding .. and its very fast ..
You know what you are? I'll tell you what you are.
You're awesome.
Thankyou so much.
Change Aspect Ratio without re-encode
By 80r in forum Video ConversionReplies: 2Last Post: 27th Jun 2011, 12:59 -
Best way to change aspect ratio....
By Han Solo1 in forum Video ConversionReplies: 13Last Post: 14th Oct 2010, 10:33 -
MeGUI x264 Aspect Ratio Tag?
By reakt in forum Video ConversionReplies: 11Last Post: 6th Aug 2010, 18:44 -
mkv wont play full screen. change aspect ratio?
By elimelim in forum Newbie / General discussionsReplies: 17Last Post: 19th Jul 2010, 19:21 -
Have to change the aspect ratio - what is the right way??
By Weef in forum RestorationReplies: 25Last Post: 4th Mar 2009, 13:14
