m8 has toshiba sd22vb it plays dvdr ok but will not play any multi dvdrs, i've read u can re-copy these discs with nero 6 and they should work ok, any tried this ?
explain fully the problem, answer there will be. 8)
The electronic components of the power part adopted a lot of Rubycons.
Multi region codes for a Toshiba Sd7200 DVD player
By swany2 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 25th Feb 2012, 13:40 -
Multi-Angle DVDs... and Blu-Ray?
By blazin-j in forum Newbie / General discussionsReplies: 11Last Post: 12th Oct 2010, 12:40 -
Toshiba SD705 - Multi Region
By Rees09 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 26th Sep 2010, 18:41 -
ReQ: Toshiba DVR20KB Multi-Region Hack
By Teac23 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Aug 2010, 05:14 -
Toshiba SD1200; wont play reg 3 dvds
By Rabu_xiah in forum DVD & Blu-ray PlayersReplies: 4Last Post: 14th Nov 2007, 11:18
