Anyone know what the exact lines of resolution is for standard cable?
I like to record certain programs on cable with my Digital 8 Camera. I was wondering how many exact lines of resolution fo you think that captures from a standard cable signal?
Anyone have any ideas?
I think the general answer would be somewhere beetween 352x480 and 720x480, leaning more toward the 352x480 side.
I think I remember reading somewhere (but I can't remember where) that 704x480 (for NTSC) is broadcast resolution.
"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
i think he means cable as in cable tv , as on a carrier RF multiplexed ..
the resolution will vary is the correct answer -- but you will never see 720x 480 or close to it ..
but what you use to capture it will determine what you have now .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I use my digital 8 camera/analog pass thru to record and it looks just as good as a normal DVD recorder on SP Mode (maybe even a bit better).
It def looks A LOT better than a normal VHS SP Mode recording.
How many lines of resolution is a typical Digital8 camera passthru? I have a TRV-320 Sony. -
D8 will give you around 450-500 lines of resolution, lower than that of MiniDV which is around 525. But that really doesnt matter if you're recording off of TV unless it is a digital source you are recording.
Why is it that my D8 recordings are MUCH better than my VHS SP recordings if they both come from the same cable source and can only capture a certain amount of lines of resolution?
Because if D8 = say 500 (good) and CATV = say 450 (not bad) and VHS = say 300 (ugly),Originally Posted by Nikos
450 --> 500 == 450
450 --> 300 == 300
Have a look
http://www.cs.tut.fi/~leopold/Ld/ResolutionComparison/I mean it in the nicest way.
How would I connect my standard cable box to my HD LCD monitor?
By Jadedrain_06 in forum Video ConversionReplies: 4Last Post: 27th Nov 2011, 13:00 -
Standard Cable w/o STB thru VCR will allow digital stations?
By rcholden in forum Newbie / General discussionsReplies: 3Last Post: 8th Nov 2009, 21:55 -
Connect standard DVD player to HDTV with S Video cable?
By rocketman in forum Newbie / General discussionsReplies: 7Last Post: 13th Oct 2007, 02:33 -
Making all videos standard resolution?
By Conformist in forum Video ConversionReplies: 7Last Post: 7th Jul 2007, 03:11 -
Standard cable on hdtv...
By bla4free in forum Newbie / General discussionsReplies: 6Last Post: 23rd Jun 2007, 23:35
