I have a few SVCDs that I attempted to convert to DVD.
I have burnt the original SVCDs and they play perfectly in my Sony DVP-S7700. I have also burnt DVD Backups using DVDXCopy and they play with no problem.
A quick rundown of my setup:
Athlon 3000+ (400fsb)
1 gig ram, (DDR3200)
Windows2000
HP external USB 2.0 DVD+RW
I have purchased SVCD2DVD and followed this guide to the "T":
https://www.videohelp.com/forum/userguides/159399.php
I have Burnt the DVD with both Nero and Copy2DVD and get the same results.
Both times I get these two problems.
1. No text in the menu (I see it is common).
2. I get great video and sound quality, but my video is split.
3/4 on the left is squished narrowed, and the remaining 1/4 on the right is a duplicate of the 1st 1/4 on the left.
So it looks like this:
12341 (all squished to fit) instead of 1234 (normal width)
I have searched the forums, and the only thing I have found is a possible mpeg2 decoder problem. I have only installed InterVideo WinDVD 4 for mpeg2 support. If I play the ifo in WinDVD it plays with no problem and I have text in my menu.
Any help is greatly appreciated
-J
J (Guest)Guest
Pioneer DVD player?
Ah - just re-read your post!
ok - have you tried the PAN & SCAN setting? (Even maybe try the PAN & SCAN sample on svcd2dvd.com on DVDRW first)
The symptoms are identical to the Pioneer.....
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
J (Guest)Guest
I wish I had a DVD+RW to use... oh well, I can always use more coasters..
I will re-author it with Pan+Scan, if it works, I'll have what I want... either way, I'll let let you know here.
Thanks for the speedy response.
-J -
J (Guest)Guest
I have now tried twice with the "Apply Pan And Scan Info" selected.
It seems to proccess just fine, but pretty quick, 25 minutes for 2 hours of video..
When I look at my output folder.. all of my VOBS are tiny.
Before my vobs looked like this:
VTS_01_1.VOB 768,594 KB
VTS_02_1.VOB 766,958 KB
VTS_03_1.VOB 767,762 KB
Now they are:
VTS_01_1.VOB 77,042 KB
VTS_02_1.VOB 75,138 KB
VTS_03_1.VOB 74,880 KB
When I try to load the IFO in WinDVD, it'll start the video, but then hangs in the first few frames.
I can post my log file if it'll help... It is pretty long even after I clean up the percentage counter.
Thanks again
-J -
J - email it to me.
flashfreakerGuest
Did you ever solve this problem? I'm seeing this type of horizontal squeeze on a DVD+RW I burned from a Tivo ty stream (using TyTool). I thought that maybe your solution (if you had one) would help in my situation too.
-Robert
DVD+R DL Duplication
By sfxssorce in forum MediaReplies: 2Last Post: 10th Jan 2012, 00:42 -
cd-r image duplication
By tealmarlin in forum Newbie / General discussionsReplies: 0Last Post: 14th Aug 2009, 16:29 -
I am Bit confuse with cd duplication..
By Sophias012 in forum Authoring (VCD/SVCD)Replies: 5Last Post: 4th May 2009, 18:36 -
DVD Slide Show Duplication
By KLouis22 in forum Newbie / General discussionsReplies: 3Last Post: 28th Aug 2008, 08:27 -
DVD duplication house
By crazymoney in forum Authoring (DVD)Replies: 2Last Post: 16th Oct 2007, 19:04
