Does there exist any software to see if the memorymodule is corrupt?
Thx,
Johny
go to www.memtest86.com and download the same.
You can probably get there from Mushkin's ad above.
Down the page left hand side you will see Memory Test, click, will take you to a description, read, click link, you'll get to memtest86 .
Download, make a floppy and run, go as deep as you want.
I would reccommend you read the whole page of advice and instructions. -
I've tried memtest. It didn't work for my system. Said that memory was bad, and it isn't. But try it anyway.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
Village,
Yeah, the directions do make that clear.
If it works at all, at least it would give you a reason to take it to a show to ask a memory vendor if he would check it for you.
I don't know about your area, but we have them monthly, and the vendors will check them for you, although most have begun charging a buck a strip, peanuts, if you ask me. And, those same vendors are probably the best to buy from, as they are there every show and will work with you.
I returned DDR, gotten another brand/clock, still wouldn't work, swapped again for SD when DD wouldn't work with my board. (Dual format)
Cheers,
George
PC memory
By alintatoc in forum ComputerReplies: 17Last Post: 17th Nov 2009, 17:24 -
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 05:16 -
Memory
By ProducerHarley in forum ComputerReplies: 1Last Post: 3rd Dec 2008, 00:38 -
I just adeed another 2GB Memory and Total says 3.25GB Memory
By videocheez in forum ComputerReplies: 17Last Post: 11th Feb 2008, 06:19 -
I'm still trying to determine how much memory is in thus USB memory stick.
By zzyzzx in forum Off topicReplies: 4Last Post: 5th Nov 2007, 14:31
