Wheneever I use DVDschrink or IC7 my system resets.
Does anybody has had this before?
The system works fine with everything else, but as soon as I use those programs to compile the movies it just resets the system.
The MS dump says it is about a driver. Well I installed my Imagefile which has only the basic stuff of WINXP PRO.
Or hase anybody heard that it could be the Memory or MOBO. It canīt be the Videocard, as I changed it with a Geforec2MX and it is the same.
My config is:
Windows XP PRO + SP1
Ti4200 64DDR RAM
Pioneer a06 drive
Pinnavle PRO TV card
2 x 60GB Seagate Harddrives at 7200rpm
512DDR Memory at 333Mhz from Kingston.
MOBO is from Liteon
Many many thanks for any help.
Johny
OK, what do you mean by "resets"?
What type of CPU do you have? AMD or Intel?
Need some more info to help.Burn Baby Burn
It's a Disk-o Inferno -
I was having this problem, My CPU was overheating. It was the only thing that was pushing my CPU enough to make it HOT enough to reboot. I figured it out by getting some probs and finding out what the specs were for my CPU.
Since then installed a Thermaltake Volcano 11 and some Arctic Silver III paste and I haven't hit 45 degrees since. BTW my CPU was crashing at 70 degrees. -
That's exactly what I was thinking when I asked the original poster what he meant by 'resets', and what type of CPU he had. It seems that AMD CPU's run hotter than Intel and are more likely to overheat and reboot. I had the same problem. Mine would shutdown and reboot at about 68 degrees.Originally Posted by rlegaultBurn Baby Burn
System Running Slow when running dvdshrink
By mn072065 in forum ComputerReplies: 7Last Post: 24th Mar 2009, 20:59 -
Help wanted for DVDShrink 3.2
By _beavis_ in forum Newbie / General discussionsReplies: 13Last Post: 6th Feb 2009, 01:11 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 20:33 -
Just wanted to say thanks!
By freebird73717 in forum FeedbackReplies: 0Last Post: 30th May 2008, 17:10 -
Monitor / Display Resets - Dying Graphics Card?
By daamon in forum ComputerReplies: 15Last Post: 17th Jun 2007, 04:41
