Wheneever I use DVDschrink or IC7 my system resets.
Does anybody has had this before?
The system works fine with everything else, but as soon as I use those programs to compile the movies it just resets the system.
The MS dump says it is about a driver. Well I installed my Imagefile which has only the basic stuff of WINXP PRO.
Or hase anybody heard that it could be the Memory or MOBO. It can´t be the Videocard, as I changed it with a Geforec2MX and it is the same.
My config is:
Windows XP PRO + SP1
Ti4200 64DDR RAM
Pioneer a06 drive
Pinnavle PRO TV card
2 x 60GB Seagate Harddrives at 7200rpm
512DDR Memory at 333Mhz from Kingston.
MOBO is from Liteon
Many many thanks for any help.
Johny
Closed Thread
Please don't cross post. One topics is enough
https://www.videohelp.com/forum/viewtopic.php?t=178606&highlight=
I am trying to run Windows 7 using Parallels software.
By CHETOB in forum MacReplies: 3Last Post: 3rd May 2012, 19:52 -
Will my pc run W7 32bit?
By neworldman in forum ComputerReplies: 6Last Post: 20th Oct 2010, 15:42 -
where is RUN on Windows 7?
By jyeh74 in forum ComputerReplies: 7Last Post: 17th Dec 2009, 19:00 -
DVD Decrypter doens't see media
By happydog500 in forum AudioReplies: 22Last Post: 28th Jul 2009, 23:41 -
Nero FLAC plugin doens't work
By happydog500 in forum AudioReplies: 0Last Post: 4th Jun 2007, 14:07
