  1. Could anyone help me ,im trying to rebuild a dvd in dvd-lab1.1 but when i try to load the vobs from the assets they will only go into 1 movie folder each meaning that i cant build the movie and have the vobs run one after another as the movie should ,any help would be much appreciated
  2. In DVD-Lab, go to the left side of the screen. There should be folders there that are marked MOVIE and MENU. Right click the mouse inside that window. You wil get a menu. In this menu, select ADD MOVIE. Another movie window will appear. Place the next VOB into that newly created window. Repeat until all VOBs are in a movie window.
    Then, go to the CONNECTIONS screen and connect the first VOB you want played to the second VOB you want played, then the second to the third, then the third to the fourth, and so on and so forth. To do CONNECTIONS, in the same window that had the MOVIE and MENU, there should be a folder listed as CONNECTIONS. Double click that. A bunch of boxes should appear in a new window that contains all the elements you are adding to your DVD. On the left side of the new window there should be a small icon that looks like a PLUS sign with a line comingout of it, that is the connections icon. Select that and conect away.
  3. thanx m8 AWESOME!!
  4. Anytime.
