When I cut the second half of the movie with myflix3, it looks perfect-starts and finishes at the correct place-but the problem is the file size is the same as the full movie-this makes it impossible to burn. Can anyone think what I am doing wrong? I have followed the guide to the T -I think. I have clicked the start frame button-entered the start frame, clicked the and frame button-and pulled the marker to the end of the mpeg. Then I have generated the output, changing the file ending to VCD. Thanks in advance!
Results 1 to 1 of 1
MPEG Streamclip MPEG-TS to MPEG4/H264 (file size & aspect ratio query)
By Heathy65 in forum Video ConversionReplies: 5Last Post: 4th Apr 2012, 12:31 -
Does half d1 alter file size at all or is it just how the bitrate is used?
By yoda313 in forum Video ConversionReplies: 14Last Post: 17th Oct 2010, 20:28 -
Perfect DVD copy with all the menu's but half the file size
By Kozanator in forum Newbie / General discussionsReplies: 12Last Post: 5th Mar 2009, 10:44 -
Cutting File size through muxing HD Audio
By Mastablastacious in forum EditingReplies: 1Last Post: 4th Feb 2008, 03:18 -
problem with cutting AVI in half with VirtualDub.
By eroy in forum EditingReplies: 1Last Post: 27th Dec 2007, 07:53
