i need help fast
i want to convert avi to svcd
well i have an avi file with 14.985 fps which i want to encode with cce but since cce does not accept 14 fps i used virtual dub to change the framerate to 29.970 fps but instead the movie became speedy
I know u can convert in tmpgenc but the quality is not that good
please tell me how do i change my framerate to 29.970 without any speeding & encode it in cce.
HELP
mIRC = Must I Really Care.....
Ok ... i'll bite.
Since nothing is impossible, i would say you have 3 options : Slim , None and F#(k All of trying to achive what you are attempting.
Hi mIRC,
Obviously, you have divX (or one of it's siblings) ..
What I would do, is:
* Import your .avi source file in vdub
* change fps to 29.970, and
* then save as a .vdr (can change to .avi if needed)
* now, proceed to feed this into CCE, making sure you have 29.970
The above will basically duplicate every frame.
But to note...
For what you are doing, CCE or TMPG would do, and there would be no
which is better.. unless you are new to video processing and you are not
familiar w/ TMPG's settings and advantages. My gut feeling is that you are
one of those who are using multi-pass routines and you haven't realized
that TMPG would progably do just as good, plus it has additional filters too.
But, you probably heard to CCE is faster, and you obtained a copy, and
am carefree away w/ your 14.985fps sources files
..well, that's ok.
Do check out the above step though, it's one way of approaching your goal
Enjoy the FORUMS :P
-vhelp
To synchronize 29,970 audio fps for 23.976 fps
By DruidCtba in forum Newbie / General discussionsReplies: 1Last Post: 27th Sep 2009, 13:01 -
MP4 29.97 fps to AVI 25 Fps
By videopetur in forum Video ConversionReplies: 4Last Post: 20th Jan 2009, 07:37 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 16:23 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 20:17 -
30 fps flv to 25 fps avi or vcd
By cd090580 in forum Video ConversionReplies: 5Last Post: 12th Nov 2007, 09:35
