Results 1 to 10 of 10
    Ive have a large uncompressed AVI file which I need to convert to a reasonable sized SVCD. However, when its uncompressed its viewable perfectly fine when using WMP of Power DVD, upon loading and selecting the SVCD (PAL) temlate .mcf file, TMPGEnc displays a B&W distorted image as follows (apologies for the pictures, its the easist way to explain..) -
    If anyone can advise what may be causing this it would be great..
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    go into vfapi settings and there are two avi (at least) readers , reverse thier order ...
    Hi thanks for responding. Ive tried numerous combinations based on what you told me, but Im afraid it makes no difference and I get the same effect. The settings for VFAPI are as follows - am I missing a plug-in, or is the order incorrect?
    Regards
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    uncheck each of the first 3 readers listed one at a time ...
    also you have 2 mpeg2 decoders listed -- uncheck the CRI one (different issue)
    Hi,
    I have unticked each one and tested conversion after each was disabled, and I still have the same effect. If I remove all 3 Im unable to import AVI files, presumeably I need to leave at least one ticked.
    Regards
  6. Have you tried frameserving from virtual dub?
  7. Член BJ_M's Avatar
    Jul 2002
    Canada
    this doesnt sound like "uncompressed AVI" then ---- which should be a huge file ..
    I captured them on the fly from a TV source, using Svideo connection, with iuVCR selecting "uncompressed" mode. A 10 second file is over 350Meg in size.
  9. Click on "AuxSet.exe". A new window will pop up. Click on "install handler". You should now be able to frameserve.
    Does that process take long - its just I have just tried this, nothing actually appears to happen, 0 frames are served, it creates a 1kb file which I cant load into TPMGEnc after a reboot.
