If theres anyone out there that has managed to enable the passthrough feature on a SONY TRV 235e or any other SONY camcorder that had this special feature to be set plz msg me. Im stuck
Results 1 to 9 of 9
I have the 22 model with passthrough . The directions should be in the manual on how to do it. Mine were. You have to change to av/ digital out on the menu of the camera. I think it is originally set for dv in not analog in dv out
Hi zoranb,
I don't have your CAM model, but I do have the TRV22 model.
It can be very confusing as to how to set up for pass-throu. I had similar
issues too w/ mine.. I coudn't figure it out.. till I tried weeks later
Basically..
* First, you set your CAM to VCR on your manual Switch,
* Then, in the MENU, you look for a VCR SET menu list
* Then, w/ a little luck, you look for somthing similar, like DV out or something
* You have to find your MENU and search through it !!
* On my, I activiated the MENU and went through the main meu,
* Then I worked my way through the PAGE(s) and found mine on PAGE 3
* Then, I was still confused cause there were tiny buttons that I didn't
...quite understant
* Then, I started to press each one to see which was doing what.
* I finally found that REC CTRL for what I needed to set, if I wanted to do
...any recording off my Satellite and onto miniDV tapes.
* There another button, A DUB CTRL right next to the button rec ctrl
...one, but I'm not sure whats' its' purpose is for sure
...this button has
So, do experiment w/ yours.
-vhelp -
i made a mistake i have the SONY DCR TRV 325E pal camcorder not the 235 like i said...sorry
I have the Sony TRV27 and also had trouble using the pass through. One very important step that I found is that is won't work with a tape in the camera. Make sure you remove your tape.
I have a Sony TRV620E but it's a United Kingdom PAL handycam so it may be different anyway.
I have no switch to change it to passthrough, it simply just does it.
You plug your cable TV or VCR etc output into the 'Audio/Video' input on the camera and the source can be seen on the camera for you to watch or just record to the DV tape, to play the source through the camera and display it on the computer I have to remove the tape if I want the PC to capture it live. -
Hi
I have a Panasonic DV camcorder. Do any body know whether it is possible set up pass through. Please share, so I can avoid buying a cpture card
Thanks for any help
Mac -
hi guys,
@ makkar,
You gotta give more details..
* make/model of your Pan dv cam
-vhelp
delete
By deuce8pro in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Jul 2010, 13:50 -
Sony TRV 138 or TRV 350: do these camcorders have "pass through"?
By tadd5181 in forum Video ConversionReplies: 1Last Post: 24th Apr 2010, 18:38 -
Sony DCR-TRV-20 external mic impedance matching
By Larry Larson in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 21st Sep 2009, 14:54 -
Sony TRV - digital, but record onto Hi8 tapes?
By OM2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 1st Jun 2009, 12:07 -
Transferring video from Sony DCR TRV 285E to PC ...need dv sample
By ganduman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 12th Mar 2009, 09:20
