On the DVD I am making,
I want to add files that can be printed out also. Can I just make how ever many folders I need for extra non-video files without worrying about player compatibility problems?
These will be how to type files and most likely .jpg images also.
Thanks.
Project might be going nicely if I could get sound durring a DV to PC capture!
Analog no problems. But DV to analog to Mpeg2?? Not really why I bought a DV camcorder!
Odd ?! What type of DV is it? - See link.Project might be going nicely if I could get sound durring a DV to PC capture!
http://www.puremotion.com/resources/technical/dvfiletypes/
If needed ,here is a DV file converter.
http://www.canopus.com/US/products/DV_file_converter/pm_dv_file_converter.asp
To answer first question - YES .I have successfully put folders on my DVD with extra stuff with no problems. I suggest you trial it with a DVD-RW, but i have had no issues.
Of course it will only be visible on a computer.
DV from DV camcorder, via firewire to the pc!
I think I'll be taking the whole deal back to Wallmart! Canon Zr60 $500 ($350 online), firewire card $30, Tapes $20, and sales tax. $600 and I can't get Audio in the DV avi files! I think it all goes back!
MY videos are getting Banded lines also with fast movement, like swing your arm quickly up and down! Arm has banded lines. I have tried 3 programs DVapp, Dvio, WinDV, and none have sound.
Analogue Captures Have sound, But I didn't buy DV for $600 to have $200 Anolgue captures! I could get VHS c for $250!
I don't know if I have a codec missing or what? -
Huh?? No DV type 1 or DV type2 ?Originally Posted by overloaded_ide
http://thetechnozone.com/videobuyersguide/Codecs/Type1-Type2-DV.html
Get a DV codec here.
http://www.mainconcept.com/downloads.shtml
Will deal with other issues later - ie: Banded lines
Lets try again.
I did have sound ocasionally, like one Avi was 2 mintue test and had perfect sound. Then 30 minute capture had NONE, then non-of the rest have sound either.
Latter I got one test with sound again, then lost it again.
I tried DV2 with one of the programs that gave me a choice, and DVIO just captures to a file, no options. The other I forget how it worked.
I did notice in one program that has a preview that the sound was playing through my speakers. So it is coming off the camera through firewire to the PC!
The fact that I had sound a couple times during short tests, make me think I have the right codec. But I don't have a clue why it worked about 3 times and not work 15 times
Black Magic Intensity Pro Questions
By gbpatriotic in forum Capturing and VCRReplies: 18Last Post: 26th Sep 2010, 14:17 -
DVD Ripping to AVI (XViD + Lame) through MKV Magic. Is it possible? How?
By Bonie81 in forum DVD RippingReplies: 3Last Post: 17th Apr 2010, 10:05 -
Magic Dvd ripper
By angelus214 in forum Newbie / General discussionsReplies: 1Last Post: 9th Nov 2008, 14:00 -
Questions about using a Black Magic Intensity Pro card
By flyingplanet in forum Capturing and VCRReplies: 1Last Post: 10th Aug 2008, 22:15 -
I/O Magic DVD ReWritable 16X Drive Not running at 16X
By mmitsch in forum DVD & Blu-ray WritersReplies: 3Last Post: 7th Jul 2007, 00:40
