Results 1 to 13 of 13
  1. primodvd or instant copy cant see my dvr-105 but windows see it and i can play dvds on it.... can anyone help me with this
  2. You need to upgrade to RNM or another burning package,as the psx engine in Primo doesn't support it.
    You may be able to get an psx update, but I am told it aint too clever.
    Go for new software.
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    prassi primo dvd is one of the best burning software around (if not the best for dvd's) and you will find it in a LOT of duplication places and studios .... though no longer made - updates are still avaiable for it ..
    and it supports the 105 , and 104 (and even 106) pioneer perfectly ..
    click here for update
  4. i no it supports it because it works on one of my machines with no problem but the other one it doesnt show up anymore.... i no its got to do wit some driver of microsofts tht accidentially got put on .... i just need to remeber what file i need to make those programs see the burner again
  5. Член BJ_M's Avatar
    Jul 2002
    Canada
    remove it from your system - boot , shut down , install it again ,, boot
  6. i have tried tht but it wont install it back and i dont have the disk that orginally came with it
  7. Член BJ_M's Avatar
    Jul 2002
    Canada
    put it on another ide channel - even temp ..
    u should not require any disk (driver) ...
  8. Hmmmmm ......... interesting to know that Primo does support all the pioneers,
    I didn't know that. I tried the updates that claimed to work, but none did, so I gave up.
    I tried everything to get it to work and finally gave up and moved over to RNM and Nero.
    I hope you have better luck than me
  9. Член BJ_M's Avatar
    Jul 2002
    Canada
    record now Max and prassi have exactly the same burning engine ..
  10. i just know i remeber having this problem about 2 years ago..... and i dl some file tht helped my software see the drive..... i was wondering what it was..... also i dl tht px engine software and installed it..... what is it for ??????
  11. Originally Posted by mol3000
    This engine update provides product updates, fixes, and new CD and DVD recorder support.
    http://support.sonic.com/Downloads/engine.asp
    Yep
    A DVDR made by RecordNow DX:
    Media Information
    Application id Prassi
    Implementation id Prassi
    You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
    Sep 2003
    Le Mans, France
    Hello,
    PrimoCD, PrimoDVD and RecordNow all use exactly the same burning engine - the PxEngine. This technology nopw belongs to Sonic, and as tompika said, it is available on the Sonic webpage.
    Future application from PrassiTech no longer use the PxEngine.
    Even if PrimoDVD is no longer developped, all the PxEngine updates will work for it; you don't have to move to RecordNow DX/MAX.
    Any more questions, don't hesitate to ask.
    JLangbridge
    Oct 2000
    Toronto, Canada
    OK I must be doing something wrong here. I use PrimoDVD 2.0.829 and upgraded with the latest px software 507 from Sonic.
    Primo still cannot detect my Pioneer DVR-106D. Nero does but doesn't work very well for DVD's. I plugged the 106 into another bus but no luck either.
    Are you sure that it supports the 106 drive already.
    Re-installed my 104 to keep burning my stuff until I find a solution.
